GW släppte flera uppdateringar till deras 40k FAQs ganska nyss. T o m Dark Angels har hunnit få en.
En av de mer intressanta sakerna:
Q: When making a Shooting attack against a unit, can Wounds from the Wound Pool be allocated to models that were not within range any of the shooting models when To Hit rolls were made (i.e. half the targeted model are in the shooting models’ range, and half are not)? (p15) A: No.
Mer godis: Heldraken vapen räknas som turrent och får skjuta i alla riktningar, noise marines får ta en blastermaster i en mindre squad, två i en större... Hittar ni några fler roliga saker?
Incubi klaives, demiklaives samt huskblade har AP2... Hello Dark eldar Deathstar..
Säger bara... Blastmasters! :)
En del nya fantasy FAQ´s ute också.
Dom intresantaste. "Q: Does the War Altar of Sigmar confer the Stubborn special rule to any character mounted upon it? (p47) A: No "
"Q: Can models choose to voluntarily move into/through a magical vortex? (p31) A: No."
"Pit of Shades or Dwellers Below, does the rider test separately from the Screaming Bell/Plague Furnace to see whether they are destroyed? (p43 & p48) A: Yes."
Q: The Maulerfiend model has a pair of magma cutters. Does this mean that if it hits with at least one Attack in the Fight sub-phase it gets to make one additional Attack with each magma cutter and if it hits with all of its Attacks, it instead makes two additional Attacks with each of its magma cutters? (p68) A: No. The Magma Cutters rule covers the effects of both the Maulerfiend’s magma cutters, which are treated as a single weapon. They are also treated as a single weapon for the purposes of Weapon Destroyed results.
Magma cutters räknas som weapons... fancy that
"Q: If a unit is embarked on a Night Scythe that is Wrecked or Explodes, do they suffer Strength 10 hits with no armour saves as per the Crash and Burn rules before they are placed in reserve? (p81) A: No."
Hoho! Noise marines blir riktigt kuliga nu. Dyra men kuliga. :)
Okej, en fundering...
Sida 67 i regelboken: "On a turn that a psyker arrives from reserve (see page 124) he cannot attempt to manifest any psychic powers that must be manifested at the start of the Movement phase."
Sida 68 i regelboken: "BLESSING Blessings are manifested at the start of the Psyker's Movement phase."
Från FAQ: "Q: Blessings are manifested ‘at the start of the Psyker’s Movementphase’ – does this mean they happen simultaneously with Reserves rolls, Outflanking rolls etc and if so which is resolved first? (p68)
A: They do occur simultaneously – as such, the player whose turn it is decides in what order these things occur as per page 9 of the Warhammer 40,000 rulebook. "
Kanske är jag trög men vad menar dom? Får man casta blessings efter man kommit in från reserves, även fast de uttryckligen skrev att man inte får det i regelboken? Eller castar man blessings först och kommer in från reserven sen, fastän man inte är på bordet? Låter konstigt i så fall.
Man kan ju inte kasta en blessing (eller nån annan kraft för den delen) om man inte är på plan, och är du på plan har du gått och därmed passerat "the beginning of the movementphase", så jag säger nej till psychic powers samma runda som man anländer från reserv.
Jag skulle säga att det innebär att du kan kasta en blessing på en enhet som kommer från reserv, men att psykern som kastar blessingen måste ha varit på bordet sen tidigare...
Ah nu känns det lite klarare, tack. Trodde först de menade att man skulle kunna casta blessings med psykers som kommer i reserv, men att det direkt motsades i regelboken förvirrade det hela. Så det hela var egentligen ganska logiskt, om man vill får man gå in med reserves innan man börjar kasta blessings och man kan därmed blessa en unit som just kommit med en psyker som sedan tidigare redan står på spelplan.
