hej
Söndagen 5 juli kör vi turnering på Saga galerian i Umeå
Shema:
Upprop: 0930
Match 1: 1000-1220
Lunch: 1220-1300
Match 2 1300-1520
Match 3: 1540-1800
Pris utdelning 1820
Anmälan: Avgiuft 50kr görs via Fantasia
Regler:
Deployment och Strategy match Schemes 1-3
1 Standard Deployment Turf War s65 och s66 stora regelboken
Schemes: A line in the sand, Power Ritual, Boddygard, Vendetta, Protekt Terretory
2 Corner Deployment Interference s65 och se neden
Schemes: A line in the sand, Make them suffer, Distract, Assasinat, Entourage
3 Flank Deployment Collect the Bounty s65 och se neden
Schemes: A line in the sand, Framed for murder, Outflank Brackthrough Boddygard
Strategy från Gaming grund 2015
Interference
Set Up
Divide the table into four 18" by 18" table Quarters.
Victory Points At the end of each Turn after the first, a Crew earns 1 VP if it controls two or more table Quarters. To control a table Quarter, the Crew must have the most unengaged non-Peon models within the table Quarter. These models cannot be within 6” of the Center of the table, or partially within another table Quarter.
Collect the Bounty
Special Whenever an enemy model is killed or sacrificed, the acting model's controller scores a number of Bounty Points depending on the type of model which was killed or sacrificed. Models are worth the following number of
Bounty Points:
Peons: 0
Minions: 1
Enforcers: 2
Henchmen: 3
Masters: 4
At the end of each Turn, after calculating VP, reset each player to 0 Bounty Points.
Victory Points
At the end of every Turn after the first, the player with the most Bounty Points scores 1 VP. Either player may also score 1 VP if the opposing player has no models left in play. No more than 1 VP may be scored from this strategy per Turn. If both players still have models in play and they are tied for Bounty Points, neither will score any VP.
Crew Selection:
Inför varje match har man 10 min att välja / göra en lista
Man spelar antingen en fraktion eller en Master vilket medelas vid Uppropet. Spelar man en 2 fraktioners master väljer man vid list bygget vilken fraktion man ska spela och medelar motstondaren och gör därefter en lista.
Deployment Strategy och Schemes. se åvan
Turneringen är nu upplagd som ett event på facebook så hjälp till att bjuda in kompisar
Övrigt HA KUL!
mvh niklas fällman
01: Fellman (Inhoppare & arangör)
02: Peter Strandgord Bet
03: Robin andersson Bet
04: Viktor Forsberg bet
05: Linus Söderberg bet
06: Anders Åden Bet
07: Erik lifbom Bet
08: Joakim Abrahamsson bet
09: Robert Ringvall bet
10: Erik Sandström bet
11: david Sandström bet
Jag är med (Jon Borg).
Anmäl mig (Erik Lifbom)! :)
Jag vill också spela (Joakim Abrahamsson)!
Jag är med! Andreas Ådén
Första posten upppdaterad med kostnad för anmälan och stratiger och deplyments Scheme kommer början på nästa vecka så nu är det bara att börja träna
updaterat
Jag är anmäld och betald: Peter Strandgård
11 betalda och anmälda hoppas v nor 20 innas söndag
Tack för en fantastisk turnering hoppas alla hade liak kul som jag tar gjärna feedback på cenarion gäng uppbygnad mm men här är räsultat listan
01: Filip Zingmark 48p
02: Robin Andersson 38p
03: Erik Lifbom 37p
04: Erik Sandström 36p
04: Fredrik Sejsing 36p
06: Joakim Abrahamsson 35p
07: Adreas Åden 34p
07: David Sandström 32p
09: Jon Borg 31p
09: Robert Ringvall 31p
11: Marcus Persson 27p
12: Oskar Segerlund 25p
12: Niklas Fällman 25p
14: Fredrik L 24p
14: Viktor Bergström 24p
16: Danile Moren 21p
17: Linus Söderman 20p
18: Benjamin Hyvenen 16p
Stort tack till alal som var med och ett extra tack till alal som hjälpte till
