Averland blitzkrieg.
Vad: 2000pts fantasy.
Var: FUSK, Umeå.
När: Lördag 10 mars.
Inga restriktioner.
Målning: Allt måste vara målat, helt och basat.
2000pts
Det kommer att spelas på en skiva så tänk på storleken på armén.
Ungefäreligt tidskema. Match 1 11.00 Lunch 13.00 Match 2 14.00 Match 3 16.00
Nytt stuff.
Det blir lite anorlunda stil på poängen och scenariot. Det är förhoppningsvis ingen armé som blir lurad av det. Målet är att
testa något nytt och kasta lite tärningar.
Scenario: Averland blitzkrieg
Victory condition: First player to score 2 scenario points, tiebreakers.
Gametime.
2h. If the gametime ends consult tie breakers.
If the game ends during close combat phase play the rest of the turn.
Scoring
Mark a 8" x 8" box in the center of the table.
In the end of each player turn starting in the 2nd players 2nd turn the player that controls the zone (uncontested) scores 1 scenario point.
Controling the zone.
A player controls the zone if he has one or more units within the zone with the majority of the models in the unit completely within the zone.
A character can not control a zone.
Contesting the zone.
A unit that is within the zone contest the zone.
A character can not contest a zone.
Tiebreakers.
If there is no winner in the end of the game use the following tie breakers.
Start with the first and if there are no clear winner consult the next.
Scenario points . The player with the most scenario points is the winner.
Units within the zone.
The player with the most units within the zone is the winner.
Victory points.
The player that has scored the highest amount of victory points is the winner.
Clarifications
Within.
A unit is within if anny part of the unit is in the zone.
Completlely within.
A unit is completley within if all models is completely in the zone.
Turn scoring example.
Player A vs Player B.
Player A runs into the scenario turn 2 with his chaos warriors.
Player B does not contest the zone. Player A scores 1 scenario point.
Player A then scores a second point during his turn three and winns the game.
Anmälningslista (max 18 spelare).
01:viggo3000
02:
03:
Men du menade väll Averland blitzkrieg 2000pts va?
01:viggo3000
02: Fellman
03:
'''In the end of each player turn starting in the 2nd players 2nd turn the player that controls the zone (uncontested) scores 1 scenario point"
Du har helt rätt i att gyrocoptern kan kontrolera en zon. Det räcker med en enhet för att contesta oavsätt hur många fiender som är där. Man ska vara ensam i scenariot för att hålla.
Jag tar och anmäler mig!
01: Viggo3000
02: Fellman
03: Erik Elinge ( Shorty )
04: Robin
05: Beddboy
06: Bebben
07: Filip
08: BlodigaEric
09: MJ
Jag kan tyvärr inte vara med :(
01: Viggo3000
02: Fellman
04: Robin
05: Beddboy
06: Bebben
07: Filip
08: MJ
09: Pontus
Jag har insätt att jag inte hinner måla klart armén i tid, så jag måste tyvärr av anmäla mig.
01: Viggo3000
02: Fellman
04: Robin
05: Beddboy
06: Bebben
07: Filip
08: Pontus
"Jag ska Huffa och puffa och blåsa UT dig ur mit hus!" =)
Såg ut som en trevlöig turnering kul med spec caraters mm
men en liten förtfrågna kan ni inte ta söndagar i stället så man kan va med
